The 88' Force 125 on my Capri idles great and starts right up, but has no power at WOT. I am getting a tach soon, but can tell it does not sound like it reaches peak rpm and is limited to about 7mph. The Comp is ~130 across the board. I went and pulled the boots off the plugs while it was running and found that cylinders 1 and 3 made no difference when pulled off, but 2 and 4 would instantly kill the motor. Also, it would idle with both 1 and 3 off at the same time! This leads me to believe I have been running on 2 cylinders the whole time.
I replaced the CDI and coils and now it only runs when plug 4 boot is removed. I see spark on all 4 plugs when grounded to the block. Haven't tested it on the water to see if the power is up, but is it strange that there is not change from shutting down 2 cylinders? Should I investigate stator or trigger as possible avenues of problems?
