Hello,
I have a 1987 bayliner with a Force motor. Model# 856x7b Serial# 3746. It has been mostly run in fresh water. (sorry for the following simplistic terminology. I am fairly new to this) The over heat buzzer sounds at at low speeds (including neutral) but it does not at higher ones. (there is no rpm guage on the boat so I don't know that information) I used an ir thermometer to confirm that it is indeed overheating at 175 deg. It has a new impeller. I tested the thermostat in hot water and it does open fully. Water comes out the thermostat opening when I removed the thermostat.
The manual mentions the pressure relief valve but I am having difficulty locating it. I don't know if this could be the problem.
I am clearly missing something. Does anyone have any ideas?
Thank you.
Thank you.
