I'm going to try to make this as detailed as possible, so beginning of summer i bought 18ft bayliner cobra with 125 force 1988. i posted on these forums after buying it about the same issue im having now, not being able to get over 2500rpms. ended up getting a whole new powerhead and doing a full swap because the #2 piston blew up while trying to troubleshoot this issue, block was in rough shape due to previous owner not running right fuel mixture come to find out but regardless. So far these are all things ive looked at/replaced im completely lost at where to go from here.
1.replaced powerhead has roughly 140 comp on all cyl
2.replaced all igniton coils because they were arcing all over the block (thought this was 100 percent the problem) issue remained
3.used timing light adjusted the timing because it actually was quite off guessing probably happened during powerhead swap.
4.hooked up inline fuel filter between fuel pump and carbs to rule out fuel starvation under load. fuel filter stayed completley full while testing on the water.
5.made marks on prop to rule out spun prop
6.taken apart carb twice for total clean also put them through ultrasonic cleaner
So on muffs the engine runs amazing, starts up in 2 seconds. revs fine in driveway. the plugs look light brown after checking them after being on the water with the boat troubleshooting. The motor shakes/misses it seems when it is at WOT it shoots right up to 2500rpms and then thats it nothing more goes about 11mph max. this is the exact same issue before doing the powerhead swap so nothing i did with the swap changed anything. at this point i can only imagine it being a few things. power packs, stator, or triggers one of those failing under load? i just dont know how i would even go about figuring out which of those it could be. any input would be much appreciated. this has been very frustrating just want to enjoy my first boat before the summers up lol.
