Jerkbait41
Banned
- Mar 28, 2020
- 2
Hello everyone,
I finally found the problem I’ve been trying to fix to no avail for some time. I pulled the intake manifold off and found two broke n reed petals. Ordered and installed Boyesen Power Reeds and the instructions say that the Boyesen Reeds require a carb adjustment. Instruction says “Carbs with Idle Air Jets controlling idle, downsize the jets. If the carb has Low-Speed Fuel Jets increase jet size. If your carb has Idle Mixture Screws turn counterclockwise .5-1 turn past stock setting. My carb drawing shows a Main Fuel Jet, a Throttle Jet, and a single Idle Mixture Screw. What do I adjust in this case? Also the idle rpm seems fast what do I adjust for idle speed? Thanks all!
