FreeBeeTony
- May 15, 2002
- 3,991
My son has a '98 25HP Force OB.
Runs but will only idle with the choke closed.
We dismantled toe carb, cleaned, replaced needle, adjusted the float level and re-assembled.
I tried adjusting the idle mixture......no help.
Any other hints?
I covered the idle air bleed jet and it had no affect???
Didn't remove the main nozzle......maybe I needed to for additional cleaning?
Any other hints?
