If bearings looks good and the surfaces of the crank are good, then reuse the bearings.
I have done this a lot of times when I have rebuilt with bore and new pistons and rings and it has worked every time.
Well you can check the value of the bearing surface both of the crank bearings and the connecting rods by measuring with a micrometer to look if they are in spec.
But most of the time i have rebuilt the value s has been in spec when the surfaces has look good.
