Trying to get a 1995 (I believe) force 9.9 (serial 0e105639) back into running condition.
Have checked compression, it is a steady 120 on both cylinders.
cleaned carb and gave it an ultrasonic bath.
spark seems very very weak. It is sparking but you cannot see the spark in the daytime without the use of a spark tester. And even on the tester it’s not very bright.
since I’m not getting anything out of the motor even when shooting some gas oil mix down the carb throat, I’m guessing my biggest issue is the weak spark.
am attempting to pull the flywheel to tests coils and other ignition parts. But there are no threaded bolt holes in the top of the flywheel. I have tried putting a little leverage with prybar at and then tapping the flywheel shaft with no luck.
any tricks to getting this flywheel off? Also once I get the flywheel off what’s the likely problem?
any help is appreciated.
