Mickey13
- Nov 8, 2019
- 36
hi, i have a mercury force 90 hp, i was told it is a 1991-1994 model. the serial number is washed off the transom and i can't seem to find the freeze plug which mercury told me would have a stamp. i also read that there might be a circular stamp on the powerhead but i couldn't find it either.
can someone recommend a repair manual?
previous owner tells me it need a starter. i can see the starter is not engaging when starting the engine. here is a picture of the stamp on the current starter. i'm not sure if parts are interchangeable through these years.
i also need a part number for the water pump.
i hear the solenoid but the starter is not moving. i'll throw a meter on there before i order though.
Thanks in advance!
Thanks in advance!
