puffitu
- Dec 30, 2018
- 555
So the other day I’m out testing the new powerhead and all goes as planed-well with the exception that my temp gauge fogged up then the voltage gage shot way up. I stopped immediately and looked it over. Went to turn key and NOTHING....looked and checked everything. Voltage checked all pertinent connections -all fine. Then came across the circuit breaker and it was tripped. That fired it right up and so, a bit gun shy went ahead and performed some speed tests and the thing runs like a rocket. Got it back to the house and started performing the usual flushing and other ritualistic checks and WHOA!!! I noticed hinge pin on the transom, where the motor hinges to go up and down-well one side was completely snapped. So just hanging on with one side of the through pin/screw. Don’t know if this happened on the trailer or as I was buzzing around. I did swap the whole thing out beacause not only did I have a new old spare from when the guy sold me this new/old powerhead and/or motor but that I have a conveniently located tree branch over where I park the boat. So that’s my story. I just hooked up the trim and tilt hydrolic lines and seems to be operating just fine. Swapped out the circuit breaker, and voltage regulator with a spare I had. All put back together and fired it up...so now my tachometer is pegged and wont move. Is there any test procedures I should be looking at?
