Windlasher
- Oct 28, 2019
- 3
Hello All:
Good morning - Newbie to forum and boats so be gentle.
I just bought an 87 Capri with a Force 85 motor in need of some love. My first boat. I am a motorcycle guy.
Anyway, Got the motor purring like a slightly used kitten. The boat seems to work well and I will concentrate on cosmetics over the winter. I have had it out on the lake about ten times this year.
The Motor will not stay up and drifts down over a period of 3 to 4 minutes. The motor has the tilt motor on the side with the hydraulic pump under it. On land or in water and not moving, the motor trims up and down quite well but will not stay up. The tilt motor sounds just great. There are no obvious leaks that I can tell. Everything that I have read here and other places indicated it was the pump, so I replaced that. Same issue. Obviously, has new oil and the reservoir is full. I have cycled it up and down many times to make sure.
So the motor seems to work fine and has a new pump with the same problem. There are two hydraulic cylinders but only one is attached to the motor/pump which gives me a few questions.
What does the second cylinder/piston on the left do since it is not attached to the hydraulic pump? Is it spring-loaded and just there to balance out the load?
Could it be the motor even though that seems to work just fine and shouldn't the pump stop the fluid from returning to the motor unless the motor is reversed?
MY next obvious choice ar the seals in the cylinders but wouldn't there be leaking hydraulic fluid if the seals were bad?
A lot of articles that I have read say there is a release valve so you can move the motor up and down manually, but I cannot locate it. Do All motors have this and I'm just missing it? The previous owner told me that the tilt and trim have never really worked so I knew this but I would still like it to work.
Thank you guys for any help you might give on these questions is much appreciated. While this is not stopping me from wandering out these last few weeks of decent weather in Minnesota, I would like to have this fixed for next season.
