I have a 75 hp Force that has too much compression when the plugs are in to turn the motor. So far I've only found a single reed cracked. I replaced the cracked red assembly and removed head cover and lower engine cover also. I couldn't find anything unusual, everything actually looked great! It turned freely by hand and pistons were clean.
I assembled everything and I can't hardly turn the flywheel by hand or with the starter sunless I remove all 3 plugs. Does this engine have a preasure release?
