First, check the telltale to make sure the opening is not plugged by debris.
Insert a wire into the opening to make sure it is free of mud, bugs, etc..
If you don't know for sure that the water pump impeller was changed this year, its time to replace it.
You will need to drop the lower unit to access it.
A repair manual is your next purchase if you plan on maintaining this motor yourself.
A factory service manual is best, but a Clymer's Force repair manual will do for most common maitainance and repairs.
Look for one here in the iboats store, or both are available on ebay.
Sure, we can help and give you general instructions, but details and understanding are best found in a manual.
So, order up a manual, and an impeller, and might as well replace the thermostat as well.
Impeller factory part number
or part number 47-430262 $30
F664068 | THERMOSTAT, (130 Degrees) $30 |
The other thing you might want to get is a fuel pump diaphram kit.
Factory Force 75/90/120 HP Outboard Motor Service Manual 90-832749 R2 March 1998
$30
Clymer manual # 751-4 , $12 used, up to $35 for new.
