Welcome Guest - Sign Up today
No announcement yet.
1989 force 125 hp tilt trim problem HELP
  • 1989 force 125 hp tilt trim problem HELP
    I have a 1989 force 125 horse power that had a badd valve body on the tilt trim I replaced the valve body and the motor now when I refilled it and took it out for a test ride under a load it blows the breaker it will go up-and-down no problem without the motor having a load on it when I say a load I mean the prop turning putting pressure on the motor any ideas
    Welcome to Iboats,
    click on the top sticky;
    https://forums.iboats.com/forum/engi...at-information
    in here you'll find most likely your answer, good luck
    if not go to the search bar & type in keywords pertaining your search
    "Success is walking from failure to failure with no loss of enthusiasm." - Winston Churchill
    • #3
      The new pump might be binding and making it tougher to move under load?
      How did you refill the reservoir ? Motor up or down when filling?
      Up? you might have over filled it and pushed oil up into the electric motor??
      OR?? the breakers 30 years old and tired?
      Using the WAG system, wild a%$ guess
      Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
      ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
      In Scenic , Beautiful San Sebastian by the sea Florida
      88 Bayliner 21CC 2001 Mercury 225 HP EFI
      PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM I WON'T ANSWER AS MY SYSTEM CAN'T REPLY TO YOUR EMAILS
      • #4
        The WAG system! Lol I like it!
        1978 Chrysler 85 HP Model # 857H8F Serial # 3258
        "If you find yourself in a hole, stop digging." ----Will Rogers----
        • #5
          lol explain
          • #6
            Originally posted by may the force be with you View Post
            lol explain
            W.A.G. = Wild *****ed Guess When all else fails, use the WAG! Lol
            • #7
              Ive been using the wag for years. Great system; not perfect but will eventually get you there lol
              • #8
                Yes, sometimes the WAG is all you have to go on.....and can sometimes result in a little FUBAR. Lol
