DunbarLtd
- Nov 8, 2016
- 335
'88 Bayliner 17ft 85HP force.
This steering part(bottom side of the bolt thread is hitting the plastic cup and tearing it up. Its maybe 1/2" too low but havent measurerd it. If I pull on on the arm manually I can get it to clear the cup but it sugs when under normal use.
There is wood under the cup thats part of the transom and I dont want water getting through. I noticed yesterday the plastic was cracked off and i could see wood. I put some marine tex on there in the meantime and placed a small piece of rubber over the bolt thread.
But Id like to know why it is hitting there? The motor is mounted as high as it can go. It has through bolts that go through the transom and it doesnt look like I can jack the motor up any but maybe there is enough play in the bolt holes to at least get a little clearance for this cup or theres something wrong with the steering arm there.
And whats the spring do thats on the bolt? Thanks for any help!
