The Force power
- Feb 3, 2019
- 2,241
I'm testing the ignition-system before I remove it of this Part motor and found no spark on #3
I have;
-disconnected the rectifier & kill-wires
- checked all wiring connections & wires on trigger & Stator
- (ohm) tested the Stator & trigger as per Factory manual = good
-tested coils individual by swapping around = good
I'm getting 400+ V. ac from switch-box wire to coils on all three
did I over look a step?
I have;
