I have a F 16 the rayder with a sportjet 120. I am trying to figure what is going on with it. It initially was not runny. Took out the carbs and cleaned them. Now starting and idling welll however when I am wot the engine climbs up but stops at around <a href="tel:3800-3900">3800-3900</a> rpm. The boat is unable to plan and feels bogged down. I took apart impeller and shaft no twigs or blocking. Thought it could be cavitation took of ride plate and resealed it tight!!! Rebuilt fir pump, new spark plugs, compression is 135, <a href="tel:145 145 150">145 145 150</a>. Good spark in all cylinders. Not sure where to go next? It starts right up however engine feels bogged down. I was thinking of rebuilding the carbs? Any thoughts would be greatly appreciated.
