Hello everyone.
I have force 150 1992 or 1991 thats has some problems with running propellerly.
What i have done so far,
New plugs
New diphrams
New bulb
New gas
New fuel lines and recirulation lines
Sync carbs
150 psi on all 5 cylinders
Cleand out the carbs, but not rebuilt them.
Have no problem with fuel pumps anymore, fuel filter stays full without bubbleS.
When i have no gear in i have to start with 3/4 full gas to get the motor to run properly.
When i manually throttles in neutrall it slowly speeds up, starts to missfiring and then just cuts out.
Have noticed it works better when rasied out of the water some.
Also habe milky white fuel in the carbs after i run it for some time
Any ideas what problems i might have.
Greatly appriciate all help.
New plugs
New diphrams
New bulb
New gas
Sync carbs
