Recently acquired a 88 Bayliner Capri I've just been doing some maintenance
I've ran it on the water plenty of times but it doesn't like to stay idle unless it's in gear . I've set the floats cleaned carbs new plugs new fuel lines and bulb tried to adjust idle screws but didn't seem to do much. Motor has 150psi compression on all 4. From what I can see the reeds look ok. Not broken or missing at least.
Only thing I have not done is check the timing. I also am suspicious if the water pump works as it should, most steam and exhaust comes out of the two holes on back and it doesn't seem to take water from muffs, but it has not shut down on the water so I don't know.
Any advice would be great .
