Cyclone
- Feb 7, 2005
- 48
All static tests from the Seloc manual of stator and rectifier test good. I removed all connections and cleaned surfaces. Is there a way to test the stator AC voltage output while engine is idling on the garden hose? Can I leave the two Green/Yellow statowires connected to the rectifier while checking? Thanks in advance.
