Most of my rebuilds of Force/Chryslers I have reused the crank seals.
Inspect them and be careful when reassemble the crank in the crank case.
They are really easy to snap if they do not line up in the groves.
Only replaced them if they were broken.
When reinstalling, I make sure the opening of the ring is placed down so when the
covers installed the seals push down and seal.
A wire brush on a drill, clean the mating surfaces.
Don't overdo as the brush can eat into the soft alum.
RTV on the bottom bearing making the seal.
Can't tell was there sillycone on the center bearings??
Doesn't need to be there.
The half joint on an outboard is precision.------Only use ---Loctite 518---as a sealer.-----It has no fillers and most if not all should squeeze out.---Do not put sealer on bearings !!------That gets you the proper " clamp up " of the bearings.-----You do not want bearings loose after assembly.-----That just spells $$$ / time wasted
Do not use silicone !------Use Loctite 518 or a product called ----" gel seal " ----From your local Johnson / Evinrude dealer.
The bottom bearing has a locator pin.
The silicone is just for the seal.
It does go on the 2 half's of the block
Okay, I think I found my first "melted piston" & I also found the exhaust-ports in the cylinder-wall have crack in them.
I'm not sure how to measure a Piston's diameter other than with a Caliper, but how do I translate that into 0.10 /0.20--0.40
