Hello again, been searching the forums, but I’m not really sure what it’s tech called, other than, it’s not burning enough fuel. I crab with this boat, so I know you have to run it out or you get the build up and oil coming out of exhaust. Took it out the other day for a joy ride with the kids. Ran it out pretty good, then “maybe” sucked up some river mud.. and the buzzer went off for over heat. Still spits same as it always has since I replaced the impeller, it immediately went into some limp mode to the boat ramp, about 400yards. With the buzzer going. Pulled it out of the water and had milk dripping. Pulled the lower checked everything, changed lower oil, no water, oil found smells like gas, so either 50:1 is to rich, or it’s not burning enough oil off and it’s a build up, but.. I ran it up and down the river but it’s still has the oil problem. Is the 50:1 ratio to much, coils not firing strong enough? It’s a 1985ish motor. Thanks for checking this out, and sharing a honest thought.
