arriva2001
- Feb 15, 2015
- 62
Hi,
I have a 1994 Force 150 Outboard motor. I want to service the water pump impeller because the overheat alarm went off last time we used it (I shut it down right away). My boat is stored at my parents' house 200 miles from me--so I want to make sure i bring all possible parts that i might need with me--because I only have one shot to fix this without having to take another trip. I purchased the new impeller, two gaskets, and a wear plate. Is there anything else that I might need to have on hand to service the water pump? Are there other wear parts or things that in the worst case scenario will need to be replaced? I would rather have those on hand "just in case" than not since I'm making a trip to do this work. Any thoughts? Also, any gotchas I need to watch for when doing this work? Do I need to drain the gearcase first? I watched a couple of youtube videos and have the factory service manual. But it doesn't really go super into detail like I was hoping. When I reinstall the lower unit, do I need loctite or anti sieze on the bolts and driveshaft? Thanks in advance for your help.
