1992 Mercury Force 50Hp.
Replaced my impeller. As I screwed down the housing, after getting the impeller in, the drive shaft wouldn't turn, and the propeller, even though it spins in neutral with the motor off, barely spins, unlike before. If I loosen the screws a little, maybe a turn or two, everything spins and turns like it did before.
Now my motor doesn't crank. BEFORE replacing the impeller, it would crank right up Every time. No problem. New battery, and new cables have been installed as well. And before screwing down the water pump housing, I spun the drive shaft a little to seat the new impeller. I spun it the correct direction.
https://youtu.be/--eERQr2ikY
