Welcome Guest - Sign Up today
No announcement yet.
Help with model number and year
  • Help with model number and year
    So I have a force 125. The guy I bought it from said it was a 89 but I'm having my doubts. It's in the shop right now so these pictures aren't the best and I'll get more tomorrow. The model number tag is faded and unreadable. Can anyone tell me maybe what year and model number? Trying to order an impeller repair kit. Thanks!
    From the color on the hood it looks like an 89.
    Under the bottom carb and under the power packs and coils,
    there's a foundry stamp.
    Sometimes the starter has a date? unless it's been changed.
    The center of the foundry stamp has the year it was made.
    The impeller 803630T is for 89 and older.
    Remove the drive and check the impeller housing.
    If it has a stainless insert, it needs a 89984T3 that fits 90-95
    The actual model # isn't needed unless you need a specific part.
    The model#s were given if ANY change was implemented.
    Even a screw change or hose clamp change warranted a new model#
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    88 Bayliner 21CC 2001 Mercury 225 HP EFI
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    • #3
      Thanks Jerry, do you know if anyone makes a kit with the gaskets and everything? There is a few on Amazon that say they will work but each one looks different.
      • #4
        The kit is about 140 OEM
        These parts are for the old style.
        The new style has the stainless insert in the housing.
        That kit is $80 OEM
        Old style
        IMPELLER 803630T
        GASKET F523031
        PLATE F523562
        These parts are for the newer style
        WATER PUMP KIT
        FK1202-1
        Gasket F694830
        Impeller 803630T
        GASKET F694031
        GASKET: F523031
        PLATE: F523562
        INSERT F694564-1
        • #5
          I think most of these parts can be bought here.
