Welcome Guest - Sign Up today
No announcement yet.
Fuel Pump Kit
  • Fuel Pump Kit
    does anyone know where I can get a fuel pump rebuild kit for my 1994 force 50 ser. no. 0E0 62441. my local dealer says it is no longer available.
    I get mine at MasterTech Marine online store......maxrules.com
    1978 Chrysler 85 HP Model # 857H8F Serial # 3258
    "If you find yourself in a hole, stop digging." ----Will Rogers----
    • #3
      Try Franz Marine, he will have if it is available and maybe if it is not available.
      • #4
        1994 was the year they transitioned to the new style pump. Both
        types of pumps were used in 1994.
        if you have the newer Mercury style square pump, the part number is.: 21-857005A1 DIAPHRAGM KIT
        If you have the old style 2 stage pump, most parts are available from any Mercury dealer, but it appears they do not sell it as a kit.
        crowleymarine.com/mercury-outboard/parts/1469_120.cfm?mdl=EITNAV
        Or Sierra brand part number 18-7806-1
        BTW, looking at your serial number, your motor should be a 1993.
        Medford, WI
        • #5
          Everything's available!!
          They sell them here, or ebay, Franz marine and bunch of other places.
          The old style (looks like a figure 8) needs just a diaphragm and gasket
          The valves hardly ever go bad..
          The square one is
          Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
          ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
          In Scenic , Beautiful San Sebastian by the sea Florida
          88 Bayliner 21CC 2001 Mercury 225 HP EFI
          PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
          • #6
            Wow! you guys are awesome. this boat and motor has been sitting covered for about 8 yrs. It looks brand new but time has taken a toll I am sure. Thanks so much for the info on the fuel pump. I am also going to rebuild the carb, as gas now leaks down the exhaust if you continue to press the primer bulb and floods the motor. but on the other hand, if it sits for a while it starts right up and idles fine. Thanks again, Al
            • #7
              Yup clean the carb and the leak should stop.
              Make sure the jets are clear.
              Top 4 posts in this forum, READ
              They have god info on your motor.
              • #8
                Well, since my last post I put a new needle seat and gaskets in the carb. started right up and ran with muffs for about 1 min. then died and would not start again. no spark. changed the 20 amp fuse, no luck. then it went from bad to worse when the starter motor just quit. not even a click sometimes. battery voltage good-13.3-maybe starter motor shot, but doesn't have many hours on it at all. but still has an electrical problem-no spark - 94 force 50 hp. 0e062441. any ideas?? thank you
                • #9
                  outboardignitiondotcom has test procedures for your motors electrical system.
