capricuddy92
- Jun 21, 2017
- 29
Hey, guys, I have a 1990 Bayliner Capri with a 1990 120 hp Force outboard.
I just put on a new prop, throttle cables and finally, a tach (20 pole was fun to find) and I want to make sure my motor is performing correctly.
She starts up at 1800-2000 RPM in neutral, I was hoping someone can point out how to lower the throttle (750 i heard is correct ) without screwing up the carbs. I believe under the flywheel there is the control arm and an adjuster screw, but I was hoping someone can put in dummy terms what I should adjust, please.
Any help would be great!
