I made a mistake to put the wrong nut into lower unit house and how can I make it out?
L liusigou Chief Petty Officer Joined May 11, 2015 Messages 456 May 18, 2019 #1 I made a mistake to put the wrong nut into lower unit house and how can I make it out?
N Nordin Commander Joined Jun 12, 2010 Messages 2,428 May 18, 2019 #2 Please more information about what model and which nut we are talking about. If it is in the gear housing it will definitely harm the gear house, but more information please.
R Redbarron%% Chief Petty Officer Joined Dec 7, 2017 Messages 479 May 18, 2019 #3 No problem unless it gets caught up in the gears and then it will pretty much tear the drive to pieces. More than a little risk involved. If you could count on it remaining on the bottom and out of the way OK, otherwise get it out
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 17,923 May 19, 2019 #4 The oil moves as the gears and shafts turn. No way, I'd leave a nut even a washer loose in there.
L liusigou Chief Petty Officer Joined May 11, 2015 Messages 456 May 23, 2019 #5 Thank you every body's replying. I have gotten the nut out from the lower unit.
