Welcome Guest - Sign Up today
No announcement yet.
1970 Chrysler 55 gear oil capacity 555BA
  • 1970 Chrysler 55 gear oil capacity 555BA
    Hi,
    I'm glad to have found this forum..
    I have the lower unit held vertically in the vise, filled it with oil from the bottom and it only took about 350ml, it dribbled a bit while I got the plug in, I just thought it would hold more..?
    I had a fresh liter to start with, and I can see the oil thru the vent plug, so I'm happy, but curious.
    Thanks,
    Jeff
    Yes the LU has a volume of 0,36 litre (12 ounces) and if you can see the oil level through the vent hole it is okey.
    • #3
      Sounds good.
      Thanks very much
      • #4
        There's a slotted screw on the side of the nosecone, don't remove.
        The drain's on the bottom.
        That screw is an anchor pin for the shift mechanism.
        Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
        ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
        In Scenic , Beautiful San Sebastian by the sea Florida
        88 Bayliner 21CC 2001 Mercury 225 HP EFI
        PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
        • #5
          Thanks, yes, I left that one alone.
          I thought I might have to take it all apart to change the seals, but I pressure tested it and it held 10 or even 15 psi for quite a while. I remember someone saying they thought it was leaking gear oil, but I'm pretty sure it was just oil/fuel from the overboard drains
