DunbarLtd
- Nov 8, 2016
- 335
I did a lot of searching and havent really seen this topic discussed much. So I wanted to start a new thread about this issue. I think I have an idea whats causing the problem but i figured id come over here and ask you guys.
After warming engine lets say first thing in morning, if i am idling out and then just immediately go full throttle it sputters or hesitates or bogs. Not sure how to describe it. But after a few seconds it will clear up and get on plane.
I believe it seems to do it more if i idle for long periods which to me sounds like a spark plug carbon issue but maybe there is another reason.
Otherwise, while running at any speed the engine runs smooth. Seems to only do it when from a stop or slowly idling. At 1/2 throttle i did not notice the problem under heavy acceleration.
Ive rebuilt the carbs before this season with new needles. Adjusted floats. Perhaps I have wrong float setting? I cant find documentation for these old Tillotsons. Maybe there is a model number on them???
I believe i set the floats just past parallel. So upside down the float sits just a tad higher than parallel. Perhaps the floats are too low and emptying the bowl when i accelerate heavily?
I even thought about bad primer bulb but ive inspected the inline clear filter(G-2 i believe) and it stays full so i think the fuel system is not leaking air and the check ball in working correctly but i dont really know how to test the primer bulb.
Any other ideas?
Any other ideas?
