Hi i have a 70hp force that is running rough. It seems to have a intermittent miss and at around 3000rpm has a knocking noise coming from the reed valve area. I have replaced all plugs and leads and all cylinders have 120 psi compression. It vibrates heavily when on the water and struggles to make it max rpm. Help
