Hi,
I'm swapping out a 1979 Chrysler 85 HP with a 1986 Force 85HP and am having some problems.
I'm using all the same cables/wires/connections that were on my 1979 OB (my boat is a 1979 Chrysler Bassrunner)
Everything works fine (throttle, hydraulic trim/tilt, etc.) except the 2 issues below
1. When I connect all 8 wires to the terminal, if the blue wire "magneto" is connected, the circuit breaker "pops" when the key is turned. If I remove the blue wire, the engine starts and runs fine, but cannot be shut off by turning off the key (or even removing the key). The same blue wire is connected on my 1979 Chrysler OB, and there is a blue wire on the other side going to the engine. There is not a blue wire on other side of the terminal going to the engine on the 1986 Force (see pictures).
2. The tachometer runs really high (like 8,000 RPMS) when the engine is clearly just idling.
Any help would be greatly appreciated!
