RocketLauncher
- Aug 1, 2017
- 16
Hey guys, my outboard does not have a kill switch and now that I need to replace the ignition switch was thinking it's a good time to add one. If I get an after market lanyard kill switch is it just a matter of running a parallel wire from one of those two black wires from under the flywheel (they connect to the top of my rectifier - that black rectifier) and connect this parallel wire to the switch? The other wire on the switch should be a ground one, right? Thank you all.
