ggundersen3
- Dec 25, 2007
- 246
I had overheat problems with this motor over the summer, spent over $1000 at a dealer who finally solved the problem(major teardown). It starts, runs, idles great, accelerats great,no overheat alarm ever again the rest of the summer. Now, when winterizing it, it ran great on the garden hose/ear muffs with water hose spicket valve wide open and discharges alot of water out of telltale holes, but when switching it over to the tank of red marine antifreeze only a trickle discharges out of telltale and after a minute or 2 the overheat alarm sounded again even though antifreeze was flowing.
A couple questions here:
1- Is it simply being starved of coolant because of that little hose running from he tank to the earmuffs/intakes is too restrictive?
2. Have I damaged anything? Because it was maybe 60 to 90 seconds of alarm sounding as I was spraying fogging oil in carb when it sounded and I continued until fogging oil stalled motor.
3. Can I no longer use tank/hose to get antifreeze through motor but instead need to to submerge entire lower half of motor in a large tank of marine antifreeze?
Answers/ideas/solutions much appreciated here!.
