jvgilbert87
- Oct 16, 2018
- 15
I recently bought a 1998 bayliner trophy 1903 19' center console. It has a Force 125 two stroke motor which the previous owner claims works perfectly. I am only getting 3200 rpms at WOT and a top speed of 8mph. It is also burning fuel like crazy. I filled it up (50 gallons) in the other day took it 10 miles out and back for a little fishing and ran out of fuel. I have taken it out multiple times and have had 2 separate reputable mechanics working on it over the last month (ever since I bought it). The first mechanic to look at it was convinced it was a fuel pump and line issue so he replaced that. The problem still occurred so I had a second opinion from another reputable shop and he was convinced it was a bad prop and throttle cables were jacked so I had those replaced and still the same problem.
So far I have had the entire fuel system replaced, throttle cable/linkage replaced, new prop, spark plugs replaced, carb looked at and adjusted, compression tests showed perfect on all cylinders by both mechanics, fuel drained and replaced etc. Both mechanics have claimed they cant find anything wrong with the motor at all. No one seems to have any idea whats wrong with it. I am running out of ideas and options. There has to be something we are missing. If anyone has any ideas please share, thank you!
