Rranger
- May 18, 2009
- 419
I have a 1993 Force 90 hp I just bought with a boat and when I got it home and dropped the drive oil, about a cup or two of clean water came out and then some nasty looking black oil. The boat hasn’t been in the water since Jan 2017 so I’m assuming my drive and prop shaft bearings are probably not long for use. I flushed with auto tranny fluid left it in over night and drained it. I’ve replaced the impellor and did a vacuum 6 lb. 20 minutes and a pressure test 15 lbs 20 minutes and it held. The unit has a drain, fill and vent plug, I put a oring on one of the plugs that didn’t have one before the tests so I’m assuming that one little oring being missing caused the water problem. Or am I missing something here?
I’m in the hunt for a outdrive or complete 90 hp for parts if possible.
Main question is can someone fill me in on other compatible outdrives off bigger or smaller force engines and other years that would work. Mine is the 1993 Force 90 hp with the two piece drive shaft.
