Mellinghouse
- Aug 4, 2018
- 15
I am brand new to boating and just picked up a 1987 18' Bayliner Capri that has a 1989 Force 125. I took it out for the first time today and it would not go above 2500rpm, then died after about 15 min of running. Got it started after letting it sit for 20 minutes, or so, but still wouldn't go above 2500rpm. Doesn't have much power out of the hole. It seems like it's loading up or running rich. I haven't adjusted the fuel mix on the carbs, because I didn't want to mess with them unless I had to. Interestingly, in reverse, the motor seems much more spunky and goes up to 4500rpm. After meandering around for a couple hours, the motor seemed to clean out a bit and run a little smoother, and actually got up to 3200rpm, but no higher.
The previous owner didn't run the boat much, so it hasn't seen much water time for the last 8-10yrs. The motor looks like it's had very little run time. Under the hood it looks nearly new, and the prop doesn't even have a knick on it.
Could this be a carb jet problem? Any info would be greatly appreciated.
