rkinross
- Jan 23, 2017
- 29
I am having problems starting my 1982 Chrysler 75 hp engine 756H2H . The problem seems to be it will crank for 3 seconds and stop even though the key is still in the “start engine” position. If I retry the engine will crank again and stop after 3 seconds. After 10 minutes of this “trying to start” the engine will finally start. After it is warmed up it starts right away. I have had the battery checked and cleaned the connections at the starter. So far local mechanics have told me to replace the starter, replace the solenoid, and replace the clutch on the bendix. I have looked closely at the gear and the part that rises up with the gear (ratchet or clutch) . Mine seem to be locked together so that when the gear moves the ratchet moves along with it in either direction. I have seen videos that claim the gear should free spin in the counter clock wise direction. I have tried to remove the starter from the engine but can not seem to free it from the mounting bracket.
Does my bendix have a one way ratchet so the gear can free spin in the counter clockwise direction?
What is the proper procedure to remove the starter? I see 2 wires (one on bottom of starter and one on top), 2 nuts on top of the starter attached to the mounting bracket, and 2 nuts under the starter (with not much clearance to remove them). I removed the wires and 2 nuts on top of the starter and it did not budge. I am thinking the bottom nuts must still be holding it somehow but there is not enough clearance to remove them.
Does the fact it cranks each time rule out a problem with the solenoid?
