My 1985 85hp force engine alarm sounded the other day after it was running for several minutes. From what I have read, the alarm sounds when there is a over heating issue. Is this correct?
I took it home and removed the lower unit to get to the water pump and impeller. The impeller looks to be in pretty decent shape but am planning on changing out the water pump anyway. I ran into a problem when I removed the lower unit. The spacer on the drive shaft came out and I removed the rubber collar. I never saw the sealing ring. I have no idea where it is. At some point I also stupidly lost the rubber collar so now I need the sealing ring and the rubber collar. (I have the spacer) I am having a difficult time finding somewhere to buy them online. Does anyone know of a supplier? Are they universal Force sizes so I know I am getting the correct size?
One last question. The inside of the lower unit is really dirty and greasy. Is this typical?
Thanks so much.
Thanks so much.
