bojango541
- Jan 27, 2009
- 128
Will a 1987 125 powerhead work on a 1994 120 HP. The 120 has the 2 piece style driveshaft, not the newer mercury style, so the splines in the crankshaft are the same, and I know the bolt pattern is the same. My only concern is the 1994 has a newer style mercury ignition and the 1987 had the prestolite ignition. Will the Mercury ignition bolt onto the 1987 powerhead? The block looks the same.
Thank you!
Thank you!
