Themanofsteel
- Jul 11, 2015
- 312
I recently purchased a 1998 Bayliner trophy with the a 120HP force. Sometimes it idles but for the most part it usually dies. When I start it, often I have to throttle quickly before it dies on me. Once Im able to throttle, it drives fine but when I go to idle it eventually dies and can be hard to restart.
Recently the issue seems to have worsened. I couldn’t even throttle quickly because it would die.
its definitely getting fuel. I have a clear filter on the fuel line and it’s filled to the top with fuel. Plus when I squeeze the fuel pump it’s tight.
I recently changed the spark plugs and decarbed the engine with Power Tune and Seafoam. I haven’t checked engine compression.
any ideas of possible problems?
