trooper1822
- Mar 2, 2013
- 65
Hello all, been gone for a while but am back and need some advice on where to go next. So I picked up bayliner trophy with a 1988 force 85 on it for 500 bucks. Guy I got it from had not run it in about a year. So did a bunch of restoration on the boat and today was the day to start it. Ran it from a gas can and after about 10 min was able to get it running. Runs fine and idles good. Ran it up in both forward and reverse. Issue is that when I run it fuel leaks from all 3 carbs. And it is leaking from multiple locations on the carbs. Also when I pump the bulb it gets hard but then eventually goes soft. So before I go and spend 60 plus on carb rebuild kits should I try taking them apart and cleaning everything first? If I need to buy carb kits what would be good ones to buy? Thanks in advance.
