"I have heard Force parts are hard to come by and its difficult to find someone to work on them." Maybe, depending on where you are located. If you live in a coastal area, I woujld think you could fine many sources to work on them. You might find it easier if you volunteer to chase the parts when needed.
These are super simple engines, and it might be better to do the minor stuff yourself. Learn how to clean the carbs, change the impeller, change the LU oil, and and to winterize (if you live in an ares where it is needed) an most of the frequently needed maintenance is done at cost. Besides you become knowledgeable and more confident in your own ability. Refer here to other more complex issues, get a OEM manual, and enjoy boating.
BTW, this advice goes for either motor.
