No Title
Thank you Jerry that was a move I had considered and now you have affirmed that for me. Another question please?
Timing the outboard and have notice two marks on the flywheel, one says 36 the other says 10. The 10 is 10 degrees before the 36 degree mark. Which is TDC? I know max timing is 36 Degrees on most all engines but this setup calls for 32* before TDC at WOT. How do I find TDC, simple gauge TDC by the piston at its max high point, ok but that says on the flywheel as 10* as seen in these pictures.
