Re: can I put diesel oil in my engine ?
Oh...gawd! This thread ought'a be good for at least 100 posts!!!
Yes ZDDP (and diesel oils) is good for flat tappet engines....I'm also using it in my old Ford Y-block!
Unfortunately ZDDP coming out of all the oils, even the diesel oils, since it interferes with the cat converters and the after treatment systems in the newest diesels.
I haven't had a close look at the latest NMMA FC-W oil make up but I would be willing to bet that it will be the last oil to have a suitable level of ZDDP until marine (4-stroke) engines are forced to use cat converters (2 years maybe?)
Most new marine engines are probably not going to have problems since most are "roller-follower" engines anyway...
We'll all probably have to switch to Aeroshell 15W50 to continue to get the high levels of zddp or start using some snake oil additive sold at high price over the counter! (illegal in California of course!!)
The EPA is really beginning pizz me off!!!
WELL
Auto oils have had the ZDDP level reduced to meet current EPA requirments
"Most"
true diesel oils should still there full dose of ZDDP (which is a good thing )
Flat tappet cams like the ZDDP
Tommays
