Hello,
I am new to this forum and not sure if I am in the right place to post. Hoping someone can help.
I have a twin mercruiser 4.2 270 stern drive with sc1000 smartcraft with dts.
When stb switch to on position, it gives 5 beeps, check engine (with no fault message) sync and transfer light stays on. Engine start, shift and throttle does not work. Port is working properly.
I checked all the harness on vip, fuse box, actuator and everything checked. I even swapped the harness and vip except sim.
where else i missed? Thank you for any help.
