Hello,
I seem to have a big problem with my Volvo D1-20B (digital panel). Starter won’t crank. So far, engine has been starting ok but some months ago I started getting the warning beep and icon in the panel screen right after starting the engine. Probably this was a warning that something (starter, solenoid, …) was in fault, but the engine was starting as good as always (other than the warnings described of course).
Now, whatever that the problem was, probably ended up breaking for good, and now the starter won’t even crank.
Today I got a new battery to be sure that is was not related to it, but it didn’t fix it. Next weekend I will be checking the voltage in the solenoid as described in https://www.passagemaker.com/technical/troubleshooter-when-your-engine-wont-start
Any other ideas on what to test? but maybe someone has had a similar issue and can give me any better idea on what to do.
Ignacio
Ignacio
