Was hoping for some help as I embark on an oil, filter, impeller, transmission change on a pair of Volvo D4-300 engines with HS80AE-B transmissions and an Onan MDKBM generator. I have figured out some of the part numbers for the Volvos but need confirmation/help...
Volvo D4-300:
40005013 Oil
22030484 oil filter
22030852 by-pass filter
21718912 fuel filter
3588475 impeller kit? What is part #3583611 “o-ring” for? Do I need? Do these engines have thermostats that need to be replaced too?
Any idea what part # 3581078 is for? Saw it listed on a previous work order.
Part # for air filter? Is it just the “insert” part # 21702999?
Part # for the compressor oil 85108974 ?
Part # for coolant (prefer already mixed, not concentrate)?
Part # for a “spare water in filter sensor”?
Part #s for spare belts?
HS80AE-B transmissions:
Part # for the gearcase/transmission oil? What about part # for filter? It takes ATF?
For the Onan:
Part # for impeller?
Part # for oil filter?
Part # for fuel filter?
Part # for coolant?
Thank you!!!!!
Volvo D4-300:
40005013 Oil
22030484 oil filter
For the Onan:
Part # for coolant?
Thank you!!!!!
