Welcome Guest - Sign Up today
No announcement yet.
New steering does not connect to my motor
  • New steering does not connect to my motor
    I am running into a slight problem with my motor. I bought a cable steering kit from UFlex and I went to look how it would attach to my 1970's evinrude... There is no tilt tube, only a tilt bolt. I have seen people put in tilt tubes after the fact but I am not sure mine allows it. What is the best way to rig up cable steering for this motor? Should I get a tube clamp that mounts on the transom? Or what other options do I have?
    Click image for larger version
ID:	10909492Click image for larger version
ID:	10909493Click image for larger version
ID:	10909494Click image for larger version
    I have a 1976 40 HP Johnson that doesn't have the tilt tube either. So I bought a tilt tube that mounts under the engine bracket in the boat. And that gives me the steering capability and tilting capability as if it was a tilt tube engine. Easy to rig up and takes most any steering cable setup too. Look into one...
    Tom Boy Boat Project https://forums.iboats.com/forum/boat...s-what-trailer
    Rebuilt trailer project https://forums.iboats.com/forum/gener...r-back-to-life
    '76 40 HP Johnson rebuild https://forums.iboats.com/forum/engin...mplete-rebuild
    Minn Kota 599 Project https://forums.iboats.com/forum/boat-...ta-599-project
    • #3
      Thanks! Is there a name to that part? I am having a hard time finding one that mounts below the engine bracket. All I can find are the ones that go off to the side.
      • #4
        Sorry I didn't post the adapter setup. I have a stick steering setup so I had to but a new stick steering kit AND their tilt tube adapter kit. The company is EZGLIDE. And the tilt tube fits at the engine to allow a steering cable to enter from either side. I posted the picture of that kit and then you can use/replace the steering cable you want. Just go to their website to see how to measure for the steering cable length.
        Hope this helps and explains how it works with your engine...
