Panoguy
- Jul 29, 2011
- 150
[FONT=arial, helvetica, sans-serif]Hi: [/FONT]
[FONT=arial, helvetica, sans-serif](The back-story):[/FONT]
[FONT=arial, helvetica, sans-serif]So, my (2.0 4-cyl) Sea Ray originally had manual steering. During the course of my complete rebuild, I beefed-up the stringers & upgraded my power to a 5.7L V8.[/FONT]
[FONT=arial, helvetica, sans-serif]I bought and pulled a Mercruiser V8 from another thrashed Sea Ray, to use heads/tin/etc. on a short-block that I built-up.
Problem is, the thing steers like a tank with the manual (non-power) steering, so I'm trying to install the Mercruiser (old-style, but perfectly functional) power steering actuator/pump/hoses/etc., that came with my purchased/pulled V8.[/FONT]
[FONT=arial, helvetica, sans-serif]My Sea Ray has a Morse rack-&-pinion, mechanical cable system... the actuator fits perfectly onto the transom plate, but the problem is, for some reason, with the original cable, the distance (@ the transom end) between the cable sheath, to where you put the clevis pin in on the end came-up short - by about 5 inches.[/FONT]
[FONT=arial, helvetica, sans-serif]The installed cable is 35 years old, so I decided that I should probably replace it all anyways, with a Seastar "The Rack" SS141xx Back Mount Rack Steering System (& get a new steering wheel in the process!). I have performed the measurements that Searstar recommends, but...[/FONT]
[FONT=arial, helvetica, sans-serif]FINALLY - my worry; will the transom end of the cable be long-enough to reach the (farther-away than manual steering) receiver on the power steering actuator, or will I somehow have the same old problem, but with a new cable??
Did Morse make a special cable to accommodate manual steering in-the-day?
Thanks for wading thru this novel!![/FONT]
