I'll try to make this as concise as possible. I have a 16ft 1984 starcraft with a 1970 60hp Johnson on it. I have added a CMC tilt to it.
My issue is the steering wheel is EXTREMELY hard to move. It has gotten worse over the last summer but I had about a million other things to address first.
With spring not too far away, I want to fix the steering before the lakes open up.
I have removed the steering cable from the motor. The motor is properly greased and moves freely as it should. The steering is still extremely hard with the cable disconnect from the motor. This leads me to believe that the cable itself is old needs to be replaced (possibly frayed wires as it binds up until it "pops" loose and then continues to be hard to turn). I do not see any visible problems with the cable but I'm assuming the inside is all rusted/frayed.
I have searched all over the cable/rack for a part number but cannot find anything. As you will see in the pictures, it also looks like maybe the cable is a little too long but if I go a foot shorter, it may be too short. I also cannot see how the cable could even be removed from the rack. Where it goes in, it looks like the rack is riveted and not meant to be taken apart.
You will also notice that I have the transom clamp style cable mounting bracket so I need to find a new rack/cable that works with this kind of setup.
Also, if I do order just a new cable, how do I know that the cable will work with the rack I have? Or should I just order a whole new rack and cable. If that is the case, will it work with my current steering wheel?
I didn't have time to measure how long the cable should be but I do have the instructions on how to properly measure the cable length.
Can anyone help me with this and possible provide some links to some options? I had to make a "custom" bracket to get the existing setup to work with the CMC tilt. I also don't know the proper name of this kind of steering cable so I don't know how to search for this kind of setup.
Thanks for the help fellas. PS I apologize for the crappy links. For the life of me, I cannot get this forum to post pictures correctly. I use several other forums and this one by far is the biggest pain in the butt to use.
https://imgur.com/71Fu3PA
https://imgur.com/9rRYy8K
https://imgur.com/YFJcYyl
https://imgur.com/cZOhS1j
https://imgur.com/5DrRUzq
